Page 1 of 15 12311 ... LastLast
Results 1 to 10 of 148
Thread: Maximising sound quality from USB
    I'm Kevin.
    Default Maximising sound quality from USB
    As a computer audio newbie, I am wondering how best to maximise the sound quality from my HP Proliant N36L (no sound outputs) to my Caiman SEG DAC.
    Thanks to Stryder5 (Gary) I have a decent USB cable, which is connected directly to my DAC.
    Would I be better off getting an internal sound card (needs to be low profile to fit the PC) or a USB device before the DAC?
    Kevin
    I'm AMusicFanNotAnAudiophile.
    Install piCorePlayer onto a RasPi, point it at your NAS, and you're up and running.
    Install a digital output HAT and hook up to your DAC.
    Chris
    Common sense isn't anymore!
    I'm Kevin.
    Kevin
    That's the kind of thing
    Chris
    I'm Kevin.
    I was thinking of this as an alternative - https://www.audiophonics.fr/en/appar...e-p-11412.html
    Kevin
    I use one of these, which may still be available somewhere? - https://www.amazon.co.uk/Fanmusic-FM.../dp/B00IS4I5W0
    Vanilla 75 ohm Van Damme coax from this to DAC and it's great for me - and I use the PC in the workroom for music source a lot these days when I can't use the main rig downstairs...
    I'm Bill.
    Kevin, you should have taken my Digione Player as well
    Chord Mojo / Sennheiser HD600
    I'm Kevin.
    Maybe....
    Kevin
    I'm Bill.
    It has gone by the way, but the Pi/Digione is a superb source into the Caiman.
    Why?
    Do you have a shitload of DSD files?
    USB is only a default interface if you have DSD, because they do not transfer over S/PDIF.
    Everything else is quite happily transferred over S/PDIF.
    USB is not a great audio interface.
    The possibility of ground plane noise and interference transfer is immense, and the device you've linked to is powered over USB, which is a poor starting point.
    Chris
