Cambridge Audio 640P Capacitor Upgrade
I recently picked up a used 640P Phono Preamp, I have been using a 540P in my bedroom system for a while and find it has a nice smooth sound. Nothing startling but easy to listen to.
My bedroom system consists of a Technics SL1700 with Grado Gold cart, Jolida 801A valve amp and some Polk Audio SDA 2A speakers.
I opened up the 640P and found it was full of Xunda electrolytic capacitors, after doing a quick search on badcaps.net I found that they are referred to as "Cheap Chinese rubbish", with wandering values and tolerances above what's printed on them. Maybe Cambridge Audio have them made to their own specs I don't know.
My wife and I listened to the 640P in stock form and found we liked the 540P better. It did have more detail and a bigger soundstage than the 540P but sounded harsh in the top end and could get flabby in the bass region.
I decided to change out all the electrolytics to see what and any difference it would make. I wanted to use Elna Simlic II's but found they were ridiculously larger than the stock caps. So I settled on Nichicon for the power supply and Panasonic FC's for the main board.
I switched out all except those in the MC section as I don't own a low output MC cart I will do that later if I get one.
One word of warning is the lead free solder used in this thing is a pain in the @ss. I had to really take my time and be very careful removing the old caps.
Here are before and after pics:
Power supply before. Notice the brown glue in places.
Power supply after:
Main board before:
Main board after:
Notice that the new caps are mostly bigger than the old ones, the Elnas were more than twice the size and the legs would not have fitted anyway.
So how does it sound now, even though I have only listened to it for a few hours it sounds great.
Immediately the harshness in the top end is gone, bass is tighter, no flabbyness. There is much more detail, I can hear every guitar pluck clearly and singers sound like they are standing in front of you. Before everything was slightly smeared now there is air between everything. The soundstage is wider as well and the backgrounds seem blacker.
Total cost was less than $30.00 U.S.
Will it beat an exotic phono preamp costing way more? No but to me for the money it's a very noticeable improvement and who knows it may improve even further with a bit more burn in time.
Phillip.
Records... the Vinyl Frontier. These are the voyages of the turntable Perspective. Its five-year mission: to explore strange new records, to seek out new artists and new sounds, to boldly go where no hyper elliptical diamond stylus has gone before!
Polk Audio SDA 1C + Yamaha C4 / M2 + Custom Made DIY Phono Stage + Pro-Ject Perspective + Pro-Ject Speed Box II + Benz Micro Ace = Magic.
