Page 5 of 36 FirstFirst ... 3456715 ... LastLast
Results 41 to 50 of 356
Thread: Custom Arm Mounting Collar for Jelco SA-750 - essential for setting correct azimuth
  1. #41
    I'm ChrisB.
    Quote Originally Posted by bobp View Post
    Shuggie, Will it fit Soundsupports armboard? If it will, I'd like to order one. The only problem, I am either too tired or too stupid to find how to send you a PM.
    Not sure you can Bob - new members have to wait for that particular special power, I think. Before you are endowed with such fortune, you need to introduce yourself to the natives and comply with one or two other teeny-weeny formalities.
    To the Welcome area with you, my man!
    Here are some clues:
    'Attention all new members'
    Here's what you should do once you've joined up to AoS - how to introduce your fine self to the folks here.
    http://theartofsound.net/forum/showthread.php?t=799
    'The basics of Ethos'
    The Rules of Engagement, or what's good form and what's not
    http://theartofsound.net/forum/showthread.php?t=17
    'Welcome one and welcome all...'
    A few more pointers for new members - of special concern to folks who're 'in the trade'
    http://theartofsound.net/forum/showthread.php?t=63
    And this one:
    'First name terms - action required'
    http://theartofsound.net/forum/showthread.php?t=8028
    Welcome to AoS, by the way!!
  2. #42
    I'm colin.
    Im at work at the moment but i will check this afternoon and if everything is ok i will send you a PM.
  3. #43
    I'm Hugo.
    Are you talking about the recessed Sound Supports armboard like this one?
    The new collar will fit any Jelco armboard, but as you can see from this picture that Hamish sent me of his 250ST on a flat armboard, you may not get the arm to go low enough unless the middle of the board is recessed by 5mm or more. Check that you have at least 5mm between the top of the Jelco collar and the bottom of the armrest plate.
  4. #44
    I'm Hugo.
    I shall be taking some of these collars up to the London Bake-Off Show tomorrow.
  5. #45
    I'm Juha.
    Great that you got the collars .
    PM sent.
    My Gear
    Source components:
    Garrard 401 in a solid birch plywood plinth / Trans-Fi Terminator T3Pro / ESCo modified Denon DL-103
    Pioneer TX-9800 tuner
    Amplification:
    Art Audio Diavolo and Conductor, Pair of XTZ Sub Amp 1's, Nick G 'Dual Phono' phono stage
    Loudspeakers:
    Bastanis Mandala Atlas with 15" sealed woofers
    Cables:
    Analysis Plus: Big Silver Oval speaker cables and Silver Oval-in interconnects, Mark Grant DSP 2.5 Dual Screened power cables
    Record cleaning
    Nitty Gritty 1.5Fi MK II
  6. #46
    I'm Graham.
    Hello,
    Great idea!
    I'd be interested in a new Jelco collar if you have any left?
  7. #47
    I'm Hugo.
    Collars have been sent out today, by Royal Mail Special Delivery to:
    Gthang
    Selfaddict
    Dalek Supreme DL
    Marco
    Puresound
    You have all received PMs with the tracking numbers.
    I'm waiting for payment for 2 further collars, and if ColinB still wants one, that leaves only one collar left.
  8. #48
    I'm Ron.
    Default Jelco arm pillar
    Quote Originally Posted by Shuggie View Post
    Actually, the few design alterations are a matter of getting the CAD drawing changed and it would be a straightforward matter to have a batch made up if there was demand.
    Hi Shuggs, there is a demand, I desperately need one, seriously, how much and where do I send the cheque to... maybe you could PM me?
    I also have a black Ittok II and an Ekos 1. Had the Ekos given the heavy works by J7 of Audio Origami.. topscale silver wiring, damping of arm tube, and decoupled gold plated counter weight. I was going to use the Ittok on my 1210 but it would have meant drilling a hole for the arm rest, as per Linn armboard, but could see probs on that one so bought a second hand Jelco750D which I now need your mod for! I will be using a Sumiko headshell but would like to trial a carbon fibre headshell? Any knowledge on this last one? The Ekos remains on my LP12 for now, but I intend trying it out on my Tekko as I'm sure it would work a treat especially as Linn arms and Jelco have more or less the same gene/DNA
    A word of friendly advice,,, take out a registered pattern on your mod, you may not be able to go into numbers production now, but later you could do so. There is always someone who will grab your idea and stick their label on it
    Jazz
  9. #49
    I'm Neil.
    Just got my collar in the post. Great packing, instructions, tools, fittings and the collar itself is a beautifully made item.
    All I can say at this stage is well done Hugo. I will try and find an opportunity to fit it later today.
    Regards D S D L
  10. #50
    Thumbs up
    Ditto!
    Turntable: Heavily-modified Technics SL-1210MK5G [Mike New bearing/ETP platter/Paul Hynes SR7 PSU & regulator mods]. Funk Firm APM Achromat with Nagaoka GL-601 Crystal Record Weight. Isonoe feet & boots. Ortofon RS-212D tonearm with Denon DL-103GL, in a Denon PCL-300 headshell, fitted with Funk Firm Houdini and Kondo SL-115 pure-silver cartridge leads.
