Results 1 to 10 of 12
Thread: RPi RopieeeXL Issues
    I'm Russell.
    Default RPi RopieeeXL Issues
    I have an RPi4 running RopieeeXL as a Roon end point.
    I want to run it wirelessly but every time I go to the configuration page, I get a message telling me there's an update downloading and not to turn it off - this message has been on all day!
    It won't allow me to make any changes to allow wireless set up - can anyone help?
    Switch off and start again, worst case scenario you'll need to rewrite ropiee XL to the card
    I'm Gary.
    AC POWER
    AMPS
    SPEAKERS
    Wharfedale Evo 4.4
    DAC
    TURNTABLE
    PHONOSTAGE
    DIGITAL
    MUSIC PLAYBACK
    Ipad Roon Remote.
    SPEAKER CABLES
    INTERCONNECTS
    I'm Russell.
    I already did thanks, a few times but when it reboots it just comes up with same ‘downloading update’ message
    Quote Originally Posted by Weeman1973 View Post
    Ah, might be an issue at the download server end.
    I'm Russell.
    Now sorted with a fresh install of RopieeeXL
    Great, had a feeling that might work
    I'm Edward.
    Russell, may I ask how you find wifi with the RPi?
    I also use RopieeeXL but on a RPi3. Works flawlessly but only with a direct connection (Ethernet). However when I try wifi it is very laggy and often Roon more often than not just gives up and reports connectivity issues.
    I've not investigated adding an aerial to the RPi. Maybe that will help.
    cheers
    E
    I'm Russell.
    Quote Originally Posted by Edward View Post
    cheers
    E
    Being honest I haven’t chance to try it out properly so couldn’t say with 100% certainty it’s performing flawlessly but for the short amount of time I had it on yesterday it worked without stalling or dropping out.
    I have BT broadband with discs on each floor of the house providing coverage but saying that I did have issues from time to time with CCA which is one of the reasons I wanted to try the Pi in my listening room which needs to be wireless.
    I'm Edward.
    Cheers Russell for the feedback. Sounds like your wifi reception is better or perhaps the wifi module on the RPi 4 is better. Or both.
