Originally Posted by
NRG
That makes no sense as what its plugged into is no where near 75 Ohm!
It may be closer to 30~40 Ohms though which would be closer to what its plugged into.
Some manufacturers like Eichmann and Canare aim to get their RCA plugs as close to 75 Ohms as possible, which is partly due to SPDIF requirements and partly because they'll still work perfectly fine in analogue applications.
Yes, the RCA socket itself is probably going to introduce another impedance mismatch, but you find that the differences between cables rapidly disappear when you are using BNC hardware and proper cable.
IMHO, the audible differences between cables appear to be related to signal reflections affecting clock signals as the data almost always seems to get through perfectly. When people on forums speak about 'bits is bits' and we get measurably bit perfect sound I don't see much discussion of the analogue i.e. clock signals.
