hi Alex,
I dont use memory play with Jriver as I don't hear any improvement with it since going to v18 of Jriver.
Also, if your pulling in your Flacs over a network it requires copying the file across the network INTO MEMORY ANYWAY before any playback can occur.
So having the "memory play" button ticked is redundant as files are loaded into memory anyway if your playing over a network.
I had a conversation with Jim Hillegass (the Jriver guy) about this and he confirmed it.
Good discussion about it here:
http://yabb.jriver.com/interact/index.php?topic=75097.0
and here
http://yabb.jriver.com/interact/index.php?topic=75123.0
The last thing I wanted to do was to convert ANYTHING (I have a similar sized library to you Alex and still relive the horror of ripping all those CDs ) and I looked in to different ways to achieve uncompressed audio from Jriver without converting.
I tried a thing called AssetUPnP, which is an audio only DNLA server?
The Naim and Linn guys talk a lot of this in their forums as it does the conversion process first THEN sends the uncompressed PCM to Jriver for playback.
I tried it, but found it to be a bit fiddly and unreliable.
It wasn't finding all my music library and didn't always play nice with Jriver.
Playlists etc didn't really work the way they were supposed to and it would have meant a lot of work to recreate them in a way that did.
So in the interests of a simple life I decided against it.
Also, it was an extra process in the chain again.
With Jriver you can select which library you listen from and I sat down and listened to the same tracks, swapping between the DNLA served "uncompressed" version and physical converted AIFF files on my HDD.
Playback from DNLA server was missing something that direct playback had.
They sounded subtly different and I preferred the direct playback.
Maybe down to network issues, who knows?
Given that it was a "do once and forget" thing with no fannying about involved and it just...worked...I decided to convert my library.
If you can get a 5% improvement (say) for nothing but your time then that works for me.
Subtle, but you miss it when its not there.
All of this stuff is based on what I'm hearing with my ears in my system in my room by the way
