Results 1 to 9 of 9
Thread: Do I need/want an Apple TV?
    I'm Craig.
    Default Do I need/want an Apple TV?
    As it says........will it be a good addition to my stuff, Squeezebox etc, and the AV kit too?
    Bluesound Node 2i
    Audio Analogue Pucinni SE
    B&W DM607 s2
    Klotz ic’s
    I'm Mikkel.
    It´s not bad at all, just slightly limited as opposed to what a Boxee i.e. can do.
    I bought one for Netflix purposes primarily. As I have Internet based TV services and PPV ability with movies already, Apples slightly slim EU offering didn´t add anything substantial value on that part.
    What do you want to do with it and what do yoy need in your setup ?
    I'm Will.
    Quote Originally Posted by icehockeyboy View Post
    I suppose it depends what you want from it...if it's just a media centre you want then a Raspberry Pi running XBMC is a cheaper option...
    Cheers, Will
    I'm Mikkel.
    Quote Originally Posted by WAD62 View Post
    snipped...a Raspberry Pi running XBMC is a cheaper option...
    Nice
    I'm Will.
    Quote Originally Posted by Riislingen View Post
    Nice
    I only have the 250mb version and it works very nicely for iPlayer etc...we'll see how it does with DVDs & Blu-Rays shortly
    Cheers, Will
    I'm Craig.
    Dunno!
    Bluesound Node 2i
    B&W DM607 s2
    Klotz ic’s
    If you have an iPad, iPhone, ipod touch or apple computer, you can do some nice stuff with it, like airplaying music to your system for example. The mirroring feature allows you to send what's on the iPad screen to the tv too, which is very handy.
    You can also use it for Netflix, renting movies, listening to Internet radio. If you jailbreak it (very easy), you can install xbmc and play flacs too.
    Sonically it's not the best, but pretty good IMHO.
    Martin
    Source: Sonos CONNECT DAC: Rega DAC Amp: Rega Brio-R Speakers: Neat Motive 2.
    My system photos
    I'm Mikkel.
    Dunno!
    Yet another case of gadget fondling...
    I'm Craig.
    Bluesound Node 2i
    B&W DM607 s2
    Klotz ic’s
