If you don't mind a two box solution...
Try a FiiO E10 & a Mini-T (or one of the many alternatives)
Or for a bit more try the Arcam rPAC instead of the FiiO, I have both, and would recommend either...
Cheers, Will
Jerry
Hifi: IPL transmission line floorstanding speakers, Squeezebox Touch, Denafrips Ares 11 DAC, DCB1 Pre-amplifier, Croft Series 7 power amp.
Custom Hifi cables HA10SE headphone amplifier and Hifiman HE-400 headphones.
AV system: LG 55B7, Denon AVR -x2300w receiver, Quad 12L (front) 11c Centre and 11L rear . Velodyne DD15 subwoofer.
You don't have to use the JPWs
This was the Teac thingummy I was thinking of http://www.richersounds.com/product/...-h01/teac-ah01
Chris
Common sense isn't anymore!
If he's prepared to spend that much I'd recommend the rPAC...
http://www.amazon.co.uk/Arcam-rPAC-C...0221091&sr=8-1
...well built, portable, and it's asynchronous
Cheers, Will
I'm alan.
There are loads of dac/amps on ebay,i had a Yulong U100 worked very well as a one box solution,only sold it when i went over to active speakers.Look under headphone dac/amps and ignore the headphone bit,thou' it's handy to have sometimes..
OOOps sorry i forgot the U100 was only a pre amp,just looked at some old photos and i was using a Tamp with it.
Try a Topping TP30 i had a TP20 which was good.
I think it is a shame to leave the JPW's languishing in a cupboard and buy crappy computer speakers.
Anyone got a really cheap T-amp they want to sell?
Jerry
I'm tony.
Jerry,
the berringher uc 202 and a chaepo t amp or if finances allow a mini t....the wee dac also serves as a respectable headphone amp....great bang for buck,sounds lovely with voices!!!!
Hi Tony,
I use this for headphones, fitted with a Mullard tube. Stunning and I don't think I will ever change it.
http://www.custom-hifi-cables.co.uk/...hone-amplifier
I will probably push the button on a T-amp if no one has a second hand one to flog.
Jerry
Check out the hifimediy USB Sabre ESS9023 DAC via ebay for about USD$50 delivered (around 35 pounds or so?)
Silly value for money, and some of the feedback on various forums is quite positive given the price.
I bought one last week and it will be added to the PC audio system in our bedroom shortly, as I gave our original USB DAC to a friend and the quality (or lack thereof!) of the onboard PC sound is driving me batty!
••• Logitech Squeezebox Touch > audio-gd NFB3(2014) w/ E9018 > fully recapped/restored Sansui AU-X701 and AU-719 > a healthy sprinkling of expectation bias > PMC GB1i speakers > Aurealis and Audio Principe cables •••
